SDM - WindPoS
Stochastic Downscaling Method for turbulent flows and its application to Wind Power Simulation
  • Home
    • Related publications
  • Gallery
  • Projects and application components
    • SDM_brine
    • Aventage
      • Aventage – Downscaling methodologies
      • Aventage – Some results and study cases
    • OceaPoS
    • Windpos
    • Modeol
  • SDM-Soft
  • Contacts
Home Projects and application components OceaPoS 2- Publications and presentations
  1.  Numerical Modelling of Hydrokinetic Turbines Immersed in Complex Topography using Non-Rotative Actuator Discs
    • 1-a-Article – Cyril Mokrani, Mireille Bossy, Marcos Di Iorio, Antoine Rousseau
    • 1-b- Abstract – Cyril Mokrani
    • 1-c- Presentation EMR SIM 2019 – Cyril Mokrani
  2. Chacao Channel Simulation
    • 2-a- Tidal energy resource characterization in Chacao Channel, Chile. Maricarmen Guerra, Rodrigo Cienfuegos, Jim Thomson, Leandro Suarez.
  3. Particle tracking visualization methodology
    • 3-a- Abstract – Wave & Tidal 2018
    • 3-b- Poster – Wave & Tidal 2018
    • 3-c- Presentation
Comments are closed.
  • New project : Aventage
    • Towards a very high resolution wind forecast chain on the sailing basin of Marseilles
  • SDM Gallery
  • Meta
    • Log in
    • Entries feed
    • Comments feed
    • WordPress.org
This text can be changed from the Miscellaneous section of the settings page.
Lorem ipsum dolor sit amet, consectetur adipiscing elit, cras ut imperdiet augue.
Powered by Nirvana & WordPress. Mentions légales & CGU & Politique de confidentialité & Cookies
We are using cookies to give you the best experience on our website.
You can find out more about which cookies we are using or switch them off in .
SDM - WindPoS
Powered by  GDPR Cookie Compliance
Privacy Overview
Strictly Necessary Cookies
Strictly Necessary Cookie should be enabled at all times so that we can save your preferences for cookie settings.
If you disable this cookie, we will not be able to save your preferences. This means that every time you visit this website you will need to enable or disable cookies again.
